[GeoNetwork-devel] [GeoNetwork opensource Developer website] #181: Wrong help definition for Date Stamp
Reporter: soazig | Owner: geonetwork-devel@lists.sourceforge.net
     Type: defect | Status: new
Priority: minor | Milestone:
Component: User interface (web) | Version: v2.4.1
Keywords: |
The definition of the Date Stamp says that it is the "Date that the
metadata was created (YYYY-MM-DDThh:mm:ss)"
However it looks more like the date when the metadata was last updated. Is
it right? Then I guess it would be good to update the help.
Thanks
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/181&gt;
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork&gt;
The ISO specs indicate date created. The North America Profile says date updates. Of course, the date of last update is far more useful to know (use for harvesting), while keeping a fixed create date is not useful, and misleading after any update (Unless one follows a procedure where any update means creating a new record--issue new identifier. Imagine what this would do to the proliferation of duplicate records in a harvesting system...). So do you want to be 'by the book' correct, or provide some useful information?
steve
  Keywords: |
  Thanks
Stephen M. Richard
Section Chief, Geoinformatics
Arizona Geological Survey
416 W. Congress St., #100
Tucson, Arizona, 85701 USA
Phone:
Office: (520) 209-4127
Reception: (520) 770-3500
FAX: (520) 770-3505
email: steve.richard@anonymised.com
HI Steve,
This issue is being addressed during the review of ISO 19115. I suggest that the actual dateStamp definition be used i.e.. "Date the metadata was created" so that if another metadata element is added for the changed date then there is no need to make changes to the dateStamp content.
Thanks.
John
-----Original Message-----
From: Stephen M Richard [mailto:steve.richard@anonymised.com]
Sent: Wednesday, 13 January 2010 2:05 AM
To: geonetwork-devel@lists.sourceforge.net
Subject: Re: [GeoNetwork-devel] [GeoNetwork opensource
Profile says date
steve
> Keywords: |
"Date that the
last updated. Is
> Thanks
Stephen M. Richard
Phone:
FAX: (520) 770-3505
This SF.Net email is sponsored by the Verizon Developer Community
Take advantage of Verizon's best-in-class app development support
A streamlined, 14 day to market process makes app
distribution fast and easy
Join now and get one step closer to millions of Verizon customers
http://p.sf.net/sfu/verizon-dev2dev
GeoNetwork-devel mailing list
Wouldn't it make more sense to change the scope notes on dataStamp to be the date of most recent update? That's what is needed for an operational system.
Can anyone suggest a use case for which the date of creation would be needed instead of the date of most recent update for a metadata record (that doesn't have to do with internal data management for the metadata producer)?
I guess this is a comment that should go into the ISO19115 review process?
steve
On 1/31/2010 5:48 PM, John.Hockaday@anonymised.com wrote:
HI Steve,
Thanks.
John
Profile says date
steve
   Keywords: |
"Date that the
last updated. Is
   Thanks
Stephen M. Richard
Phone:
FAX: (520) 770-3505
Stephen M. Richard
Phone:
FAX: (520) 770-3505
system.
+1
producer)?
I also don't see a rationale for an original metadata date. The concept of dateLastModified is very practical in harvesting and search operations. If it is never changed, then it is the original date. The date of the resource being published is also valuable (as a different parameter) to the publication and citation process.
steve
HI Steve,
Thanks.
John
Profile says date
steve
    Keywords: |
"Date that the
last updated. Is
    Thanks
Stephen M. Richard
Phone:
FAX: (520) 770-3505
Douglas D. Nebert
Senior Advisor for Geospatial Technology, System-of-Systems Architect
FGDC Secretariat T:703 648 4151 F:703 648-5755 C:703 459-5860
