[GeoNetwork-devel] [GeoNetwork opensource Developer website] #250: Repeated OGC WMS harvest leaves behind orphaned resources - ID directory/thumbnails
Reporter: awalsh | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.5.1
Component: General | Version: v2.5.0
Keywords: OGC WMS, harvesting |
Using 2.4.3 GN and also the BlueNet GN repeated (periodic) harvest
creates a new set of ID numbers directories and resources (thumbnails) in
the data directory but doesn't remove the old set of ID numbers
directories and thumbnails. E.g harvest 1 gets 4 layers and makes
ID directories/thumbnails 10,11,12,13 then harvest 2 runs and makes ID
directories 14,15,16,17.
The end result is an ever increasing number of orphaned directories/files
especially if harvests run frequently.
Suggest a way to fix this is to remove the old directories/thumbnails or
more efficient
re-use the same IDS on each re-harvest.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/250&gt;
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork&gt;
