[GeoNetwork-devel] [GeoNetwork opensource Developer website] #264: SQL Error
#264: SQL Error
Reporter: osjonathan | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.6.0 RC0
Component: General | Version: v2.6.0
Keywords: |
I tried to delete the "sample" group from 2.6.0RC0. The page gave me the
following error:
SQLException : ORA-02292: integrity constraint (GEONETWORK.SYS_C003369)
violated - child record found
The console contains this error:
2010-08-02 09:13:17,451 ERROR [jeeves.service] - Exception when executing
service
2010-08-02 09:13:17,451 ERROR [jeeves.service] - (C) Exc :
java.sql.SQLException: ORA-02292: integrity constraint
369) violated - child record found
2010-08-02 09:13:17,451 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
   <message>ORA-02292: integrity constraint (GEONETWORK.SYS_C003369)
violated - child record found</message>
   <class>SQLException</class>
   <stack>
     <at class="oracle.jdbc.driver.DatabaseError" file="DatabaseError.java"
line="112" method="throwSqlException" />
     <at class="oracle.jdbc.driver.T4CTTIoer" file="T4CTTIoer.java"
line="331" method="processError" />
line="288" method="processError" />
     <at class="oracle.jdbc.driver.T4C8Oall" file="T4C8Oall.java"
line="745" method="receive" />
     <at class="oracle.jdbc.driver.T4CPreparedStatement"
file="T4CPreparedStatement.java" line="216" method="doOall8" />
file="T4CPreparedStatement.java" line="966" method="executeForRows" />
     <at class="oracle.jdbc.driver.OracleStatement"
file="OracleStatement.java" line="1170" method="doExecuteWithTimeout" />
     <at class="oracle.jdbc.driver.OraclePreparedStatement"
file="OraclePreparedStatement.java" line="3339" method="executeInternal"
file="OraclePreparedStatement.java" line="3423" method="executeUpdate" />
     <at class="jeeves.resources.dbms.Dbms" file="Dbms.java" line="263"
method="execute" />
   </stack>
   <request>
     <language>en</language>
     <service>group.remove</service>
   </request>
</error>
Database is Oracle 10.2.0.4.
My guess is because something in the database is still using the "sample"
group (a template). If that's the case GeoNetwork should either give a
"something is in this group" error, or should re-assign things using that
group to no group.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/264&gt;
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork&gt;
#264: SQL Error
Priority: major | Milestone: v2.6.0 RC2
Keywords: |
Changes (by ticheler):
  * milestone: v2.6.0 RC0 => v2.6.0 RC2
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/264#comment:1&gt;
#264: SQL Error
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by josegar74):
  * status: new => closed
  * resolution: => fixed
Comment:
Probably caused because some metadata records should be owned by sample
group. Set no group owner automatically seem not a good option to be done
by GeoNetwork.
Use Transfer Ownership to transfer the metadata ownership from sample
group to another group, later can be possible delete the sample group
without errors
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/264#comment:2&gt;
