#272: Reproducable "Error 500" inducement
Reporter: osjonathan | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.6.0 RC2
Component: General | Version: v2.6.0RC1
Keywords: |
I have a template I'm customising (based off the "preferred" 19139. It all
goes well until I get to the metadata part at the bottom.
If I click the little "x" (close cross) next to either "Metadata language"
or "metadata standard name", not only does the item not disappear, when I
next try and "save", I get an 500 error.
Screenshot with the guilty attributes highlighted.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/272>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
Keywords: |
Comment(by osjonathan):
If I go into the "metadata" tab (under "by package") in the left column, I
get only the metadata stuff up. On that page I can remove the two
offending items by clicking the "x" and it doesn't give the 500.
So it's restricted to the main editor.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/272#comment:1>
#272: Removing element issue in default view
Keywords: |
Comment(by Fxp):
Also described in #274
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/272#comment:2>
Keywords: |
Changes (by justinrowles):
* cc: justinrowles (added)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/272#comment:3>
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by Fxp):
* status: new => closed
* resolution: => fixed
Comment:
Fixed in r6474
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/272#comment:4>
