#286: Metadata template issue
Reporter: osjonathan | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: critical | Milestone: v2.6.0 RC2
Component: General | Version: v2.6.0RC1
Keywords: |
I have a metadata template that's supposed to look like metadata1.png &
metadata2.png.
So I cancel out of that, end up back at the main screen, and then search
for random metadata. I click the "+ Metadata" next to it which makes the
metadata pop up. Fine.
Problem is, if I now go back to the admin page "New metadata", using the
exact same template I get something very different with all manner of
gibberish on it.
The output can be seen in brokenmeta(1-5).png.
I can provide a GeoNetwork zip export of my template or even an entire
Oracle database if you want (it's just dev stuff at present so quite
small).
Please note - while the screenshots are from a customised GeoNetwork
2.6.0RC1 build, I tried it with a stock GeoNetwork 2.6.0RC1 and the bug
still happens, so it's not my changes.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/286>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
Keywords: |
Comment(by osjonathan):
Forgot to mention - Restarting the server makes it display the template
fine again until you next view metadata. There may also be other triggers
but that's the first reproduceable one I found.
Ticket URL: <https://trac.osgeo.org/geonetwork/ticket/286#comment:1>
Priority: minor | Milestone: v2.6.0 RC2
Keywords: |
Changes (by josegar74):
* priority: critical => minor
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/286#comment:2>
Keywords: |
Comment(by Fxp):
We don't have the view used in the screenshot but I think user just need
to change from advanced to default view in order to have the same layout.
The last view used by current user is kept in the session (that's why
restart make the default view used again).
The default view is used for the search results display.
Ticket URL: <https://trac.osgeo.org/geonetwork/ticket/286#comment:3>
Keywords: |
I tried the process I listed above to create the bug and sure enough got
the dodgy-looking metadata template. Then I click the "default view" and
sure enough, it starts looking like it should. So thanks for that, a
temporary fix at least.
But I still posit this is a bug.
At no point during this session have I set it to non-default
intentionally. My process is (from freshly restarted server):
i) Click "search" (blank field)
ii) Click "metadata" next to one of the results
iii) Go to admin page.
iv) Click "Create new metadata".
v) Click "create" using the default template/group.
So exactly five clicks, and from a user's perspective, none of them should
change any view settings.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/286#comment:4>
