[GeoNetwork-devel] [GeoNetwork opensource Developer website] #291: "Actions on selection" issues
Reporter: osjonathan | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.6.0 RC2
Component: General | Version: v2.6.0
Keywords: |
Beyond those issues reported elsewhere that are currently open (287, 288
(enhancement), 265), some more issues with the "actions on selection"
function for search results. Grouped here for convenience rather than a
bunch of tickets (but I can create seperate tickets in the future if you
want).
a) I "transfer ownership" of two items. The top-of-screen pop-up confirms
success. But when I close that bit I get a blank-results pane. Screenshot:
b) I run a "advanced"->"restrict to" search with the "kind" being
template, so my results are only templates. I select any number of them
(doesn't seem to matter) then use the "display selected only". This then
gives me 0 results. Works fine with Kind: Metadata.
c) (more a suggestion) "Print selection" exports to a PDF. Should this not
therefore be called "Export to PDF". Personally I expected a "print"
function to actually send stuff straight to the printer (I prefer the PDF,
it's just a wrong-name issue).
d) Like Item (b) above, "Print Selection" doesn't export anything for
selected templates, only metadata.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/291&gt;
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by josegar74):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/291#comment:1&gt;
