#304: WFS Harvester XSLT bug
Reporter: JoshVote | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.5.1
Component: General | Version: v2.5.0
Keywords: harvester xslt |
My 2.4.2 / 2.4.3 geonetwork instance is failing to harvest the
MD_Metadata/distributionInfo/MD_Distribution/ transferOptions/
MD_DigitalTransferOptions/onLine/CI_OnlineResource/linkage/URL from some
of my WFS’s (all version 1.1.0).
I did a bit of digging and it looks like it’s because the root element of
the ‘faulty’ WFS GetCapabilities response is defined with no prefix (See
below).
<WFS_Capabilities xmlns="http://www.opengis.net/wfs" version="1.1.0"
xsi:schemaLocation="http://www.opengis.net/wfs
http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
Whereas the WFS’s that are being harvested correctly all specify the root
element as
<wfs:WFS_Capabilities xmlns:wfs="http://www.opengis.net/wfs"
version="1.1.0" xsi:schemaLocation="http://www.opengis.net/wfs
From what I can tell both are valid XML so I started to think it may be a
bug with GN. Having a look at geonetwork/xsl/conversion/import
/OGCWxSGetCapabilities-to-ISO19119_ISO19139.xsl there is a section that
tests
test="name(.)='wfs:WFS_Capabilities' or name(.)='wps:Capabilities'"
Which is only testing the Prefix name, not the actual namespace URI that
the prefix is representing. It should really read something like the
following (I’m no XSLT expert so there may be a more succinct way of doing
this...)
test="local-name(.)='WFS_Capabilities' and namespace-
uri(.)='http://www.opengis.net/wfs’ or local-name(.)='Capabilities' and
namespace-uri(.)='http://www.opengeospatial.net/wps’"
I’ve attached a patch of this change, I haven’t searched for any other
instances of this issue...
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/304>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
