[GeoNetwork-devel] [GeoNetwork opensource Developer website] #320: allow resolutions/units to be configurable in config-gui.xml
Reporter: landry | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.6.0
Component: Web Map Viewer | Version: v2.6.0
Keywords: openlayers |
So far, config-gui.xml only permits to set projection/extent for the main
map viewer/search map, it'd be nice if resolutions array/units could be
configured there too instead of being hardcoded to 'degree + autofill
scale array'. As of now (i don't work in WGS84, nor on the whole world
extent), i have to manually hack units:'m' and the scales/resolution array
in the gn.libs.map.js file.
As a side note, it looks to me that gn.libs.map.js is built from some of
the scripts/ol*.js files, but how so, and which ones ? it's not listed in
scripts/full.cfg, and i'd like to do modifications on the original files
when debugging - that supposes the include lines in xsl/main-page.xsl has
to be modified too..
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/320&gt;
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork&gt;
Comment(by landry):
Oh, and there's a typo in ol_minimap.js line 46 introduced in r6302:
constrols vs controls
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/320#comment:1&gt;
Comment(by josegar74):
1) For debug you can add in URL debug=true parameter, using then the non
compressed javascript files.
2) About full.cfg file, is not really used since the change to maven. Now
is used yuicompressor-maven-plugin (see web/pom.xml)
3) You can specify in config-gui.xml the resolutions for layers and other
options/parameters. For example:
   <layer server="http://localhost:8080/geoserver/wms&quot; tocName="Borders"
params="{layers: 'gn:gboundaries', transparent: 'true', format:
'image/png'}" options="{}" />
you can setup this in "options" as you do in OL.
4) I'll check about the typo. Thanks for reporting
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/320#comment:2&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords: openlayers
Changes (by landry):
  * status: new => closed
  * resolution: => invalid
Comment:
Duh. stupid me. Of course i'll set it up in options hash.. marking the
issue as invalid then. Thanks for the info and your work in the ol/mapfish
integration!
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/320#comment:3&gt;
Thanks for reporting.
If you get any issue working with the options/params hash, reopen the
issue, please
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/320#comment:4&gt;
#320: parse and use mapSearch layers setting
      Type: defect | Status: reopened
Resolution: | Keywords: openlayers
  * status: closed => reopened
  * resolution: invalid =>
Comment:
Hmm.. i still have a little related issue (hence changing summary)
in xsl/main-page.xsl, when initializing minimaps in initMapsSearch, the
AdvancedSearch.init() call isn't given mapOptions as last parameter. This
is needed to apply user-specified params.
secondly, backgroundLayers is used for all three maps, and
config/mapSearch/layers/layer config key is unused. i think
xsl/geo/utils.xsl should have a second section to parse it, and use the
corresponding layer config where appropriate.
Attached diff fixes both small problems.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/320#comment:5&gt;
