[GeoNetwork-devel] [GeoNetwork opensource Developer website] #321: Geonetwork starting twice?
Reporter: osjonathan | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.6.0
Component: General | Version: v2.6.0RC2
Keywords: |
I've just noticed that Geonetwork appears to start twice. I'm pretty sure
I've not done anything to the jetty install or anything, and I'm running
the .bat file that comes with it (attached is my version - I'm 99% certain
it's stock).
If you look at the attached log you'll see around line 390:
2010-09-20 14:43:28,080 INFO [jeeves.engine] - Startup time is : 9 (secs)
2010-09-20 14:43:28,080 INFO [jeeves.engine] - === System working
2010-09-20 14:43:28,813 INFO [jeeves.engine] - === Starting system
2010-09-20 14:43:28,813 INFO [jeeves.engine] - Java version : 17.0-b17
And then it proceeds to do the entire loading thing again, albeit faster
the second time:
2010-09-20 14:43:33,837 INFO [jeeves.engine] - Startup time is : 5 (secs)
2010-09-20 14:43:33,837 INFO [jeeves.engine] - === System working
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/321&gt;
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork&gt;
Keywords: |
Comment(by osjonathan):
This would probably also explain this error in the log:
2010-09-20 15:06:05,920 DEBUG [org.jzkit.z3950.server.Z3950Listener] -
Starting ZServer on port 2100 (timeout=300000)
2010-09-20 15:06:05,935 ERROR [org.jzkit.z3950.server.Z3950Listener] -
Problem
java.net.BindException: Address already in use: JVM_Bind
         at java.net.PlainSocketImpl.socketBind(Native Method)
         at java.net.PlainSocketImpl.bind(Unknown Source)
         at java.net.ServerSocket.bind(Unknown Source)
         at java.net.ServerSocket.<init>(Unknown Source)
         at org.jzkit.z3950.server.Z3950Listener.run(Z3950Listener.java:69)
That only apepars when the program starts the "second" time.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/321#comment:1&gt;
#321: ZServer fails with multiple .. instances?
Keywords: |
Okay, the original bug may not be a bug. I think it's because I have two
directories in the "web" directory.
But the second ZServer initialisation failure is still a bug (I guess
because it's trying on the same port).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/321#comment:2&gt;
      Type: defect | Status: closed
Resolution: wontfix | Keywords:
Changes (by ticheler):
  * status: new => closed
  * resolution: => wontfix
Comment:
This seems a system configuration problem. Two different Z-server ports
need to be configured
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/321#comment:3&gt;
