#334: copy/paste error in xsl/main-page.xsl
Reporter: landry | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: critical | Milestone: v2.6.0
Component: Web Map Viewer | Version: v2.6.0
Keywords: |
In initMapViewer(), the projection/bounds/restrictedBounds values are
taken from /root/gui/config/mapSearch/ config tree, whereas they should be
taken from /root/gui/config/mapViewer subtree.
<xsl:when test="/root/gui/config/mapViewer/proj/crs/@code">
var projection = "<xsl:value-of
select='/root/gui/config/mapSearch/proj/crs/@code'/>";
</xsl:when>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/334>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
