[GeoNetwork-devel] [GeoNetwork opensource Developer website] #337: Metadata indexing uses old INSPIRE setting
Reporter: josegar74 | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.6.1
Component: General | Version: v2.6.0
Keywords: |
The metadata indexing uses the old INSPIRE setting in config-gui.xml file,
instead of the new setting in the Administration GUI.
As the old setting is not in config-gui.xml, now INSPIRE stuff is indexed
causing no results in search.
A workaround to get working INSPIRE is to add also in geonetwork/WEB-INF
/config-gui.xml the old setting also.
<config>
   <inspire>1</inspire>
A restart of GeoNetwork is needed and a reindex of metadata in the
Administration panel.
The search panel is using the Administration GUI setting correctly, to
show INSPIRE panel.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/337&gt;
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by josegar74):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/337#comment:1&gt;
