#380: Metadata export/import
Reporter: osjonathan | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.6.2
Component: General | Version: v2.6.1
Keywords: |
I exported a metadata template from a 2.6.0 install using the export
(ZIP).
I've now installed 2.6.1 and am trying to "metadata import" this (I
deleted the database). But this isn't working. When I try and import the
metadata.xml from the zip I get:
"group1singlemetadata.xmlynothing_none__none_"
I'd also like to point out the error-message isn't very regular-user
readable.
Attached is the metadata.xml.
It appears that I need to import the zip file as a "MEF". I got lucky by
fiddling with controls. The problem is, the page isn't very clear on
different formats, and the errors aren't that helpful.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/380>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
