#427: DB setup / if no db specific file exist, use the default
Reporter: fxp | Owner: geonetwork-devel@…
Priority: minor | Milestone: v2.7.0
Component: General | Version: v2.6.2
Keywords: |
Objectives : reduce the number of SQL files to maintain (at least for data
which are equals for all).
The following files are removed:
D src/main/webapp/WEB-INF/classes/setup/sql/create/create-db-
mckoi.sql
D src/main/webapp/WEB-INF/classes/setup/sql/data/data-db-postgis.sql
D src/main/webapp/WEB-INF/classes/setup/sql/data/data-db-mckoi.sql
D src/main/webapp/WEB-INF/classes/setup/sql/data/data-db-mysql.sql
D src/main/webapp/WEB-INF/classes/setup/sql/data/data-db-oracle.sql
postgres.sql
sqlserver.sql
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/427>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by mcr):
Please have a look at
http://trac.osgeo.org/geonetwork/ticket/396
I think there is some relationship between these two tickets
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/427#comment:1>
Type: enhancement | Status: closed
Resolution: fixed | Keywords:
Changes (by fxp):
* status: new => closed
* resolution: => fixed
Comment:
r7201
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/427#comment:2>
Type: enhancement | Status: reopened
Resolution: | Keywords:
Changes (by mcr):
* status: closed => reopened
* resolution: fixed =>
Comment:
GAST support is broken.
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/trunk/gast/src/main/java/org/fao/gast/lib/DatabaseLib.java
method
loadSqlDataFile(String url)
should use data-db-default.sql
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/427#comment:3>
Priority: minor | Milestone: v2.9.0
Changes (by ianwallen):
* milestone: v2.7.0 => v2.9.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/427#comment:4>
