#444: CSW filters don't match Dublin Core identifiers
Reporter: rcoup | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: Catalog server | Version: v2.6.3
Keywords: |
Dublin core records aren't retrievable via CSW `GetRecords` queries using
a filter on the `dc:identifier` element.
1. add a record (via template, upload, or CSW Transaction). See example
attachment.
2. head to http://localhost:8080/geonetwork/srv/en/test.csw and paste in
the following query. Notice how you get 0 results.
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
xmlns:gmd="http://www.isotc211.org/2005/gmd" service="CSW"
version="2.0.2" resultType="results">
<csw:Query typeNames="csw:Record">
<csw:Constraint version="1.1.0">
<Filter xmlns="http://www.opengis.net/ogc">
<PropertyIsEqualTo>
<PropertyName>dc:identifier</PropertyName>
<Literal>12345678-1234-1234-abcd-
12345678901a</Literal>
</PropertyIsEqualTo>
</Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
3. Change the query to the following. Notice how you get 1 result, so the
record is definitely there.
<PropertyIsLike wildCard="*" escape="\" singleChar="?">
<PropertyName>dc:title</PropertyName>
<Literal>*Test*</Literal>
</PropertyIsLike>
</Filter>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
* Using `identifier`, `apiso:identifier`, `dc:identifier`, `Id`, etc as
the `PropertyName` doesn't make any difference.
* ISO19139 records are returned (using a `PropertyName` of either
`apiso:identifier`, `dc:identifier`, or `identifier`), it appears to be
only Dublin Core records that are affected.
* the `dc:identifier` is in the metadata DB table as the `uuid` for the
record.
* using other filters (eg. `PropertyIsLike`) on the `dc:identifier`
element doesn't work either.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/444>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
