[GeoNetwork-devel] [GeoNetwork opensource Developer website] #504: Trunk: error opening groups
Reporter: aperi2007 | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.6.4
Component: General | Version:
Keywords: |
using the trunk version, the r7719 version, and a Postgres as DBMS.
Try-ing to open the "group management" section I'm have
this error
>The requested operation could not be performed.
>MissingParameterEx : name
The log report this error
011-05-17 00:59:07,465 INFO [jeeves.request] - HTML Request (from
159.213.22.55) : /geonetwork/srv/en/group.update
2011-05-17 00:59:07,465 DEBUG [jeeves.request] - Method : GET
2011-05-17 00:59:07,465 DEBUG [jeeves.request] - Content type : null
2011-05-17 00:59:07,466 DEBUG [jeeves.request] - Accept :
text/html,application/xhtml+xml,application/xml;q=0.9,*/*;q=0.8
2011-05-17 00:59:07,466 DEBUG [jeeves.request] - Session id is
974B66DDAA40E5975E7782FDEBD28261
2011-05-17 00:59:07,466 INFO [jeeves.service] - Dispatching :
group.update
2011-05-17 00:59:07,467 DEBUG [jeeves.service] - -> no input parameters
2011-05-17 00:59:07,468 ERROR [jeeves.service] - Exception when executing
service
2011-05-17 00:59:07,469 ERROR [jeeves.service] - (C) Exc :
2011-05-17 00:59:07,471 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="missing-parameter">
   <message>name</message>
   <class>MissingParameterEx</class>
   <stack>
     <at class="jeeves.utils.Util" file="Util.java" line="77"
method="getParam" />
     <at class="org.fao.geonet.services.group.Update" file="Update.java"
line="55" method="exec" />
     <at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="230" method="execService" />
file="ServiceInfo.java" line="139" method="execServices" />
     <at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="408" method="dispatch" />
     <at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="705" method="dispatch" />
     <at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="196" method="execute" />
file="JeevesServlet.java" line="100" method="doGet" />
     <at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="627" method="service" />
line="729" method="service" />
   </stack>
   <object>
     <request />
   </object>
   <request>
     <language>en</language>
     <service>group.update</service>
   </request>
</error>
Andrea Peri.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/504&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
      Type: defect | Status: closed
  Priority: major | Milestone: v2.7.0
Resolution: fixed | Keywords:
Changes (by fxp):
  * status: new => closed
  * resolution: => fixed
  * milestone: v2.6.4 => v2.7.0
Comment:
Fixed in r7726.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/504#comment:1&gt;
