[GeoNetwork-devel] [GeoNetwork opensource Developer website] #507: Error creating a metadata child
Reporter: aperi2007 | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
using the thunk version (r7730)
I see an error trying to create a child from a metadata.
Creating before a series metadata and after using the
option "create child" try to create a child of it.
When I try "save and close" I see an error with this message.
>The requested operation could not be performed.
>XPathException : A sequence of more than one item is not allowed as the
first argument of string() (<download/>, <download/>)
The log report this :
2011-05-18 11:47:16,232 INFO [jeeves.service] - -> dispatching to
output for : metadata.show
2011-05-18 11:47:16,378 INFO [jeeves.service] - -> transforming with
stylesheet : /home/archivio/tomcat-website/website/geonetwork/xsl
/metadata-show.xsl
Error on line 2831 of metadata-iso19139.xsl:
   XPTY0004: A sequence of more than one item is not allowed as the first
argument of
2011-05-18 11:47:16,743 ERROR [jeeves.service] - -> exception during
transformation for : metadata.show
2011-05-18 11:47:16,743 ERROR [jeeves.service] - -> (C) stylesheet :
/home/archivio/tomcat-website/website/geonetwork/xsl/metadata-show.xsl
2011-05-18 11:47:16,743 ERROR [jeeves.service] - -> (C) message : A
sequence of more than one item is not allowed as the first argument of
2011-05-18 11:47:16,743 ERROR [jeeves.service] - -> (C) exception :
XPathException
2011-05-18 11:47:16,748 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
   <message>A sequence of more than one item is not allowed as the first
argument of string() (&lt;download/&gt;, &lt;download/&gt;)</message>
   <class>XPathException</class>
   <stack>
     <at class="net.sf.saxon.expr.Expression" file="Expression.java"
line="981" method="typeError" />
     <at class="net.sf.saxon.expr.CardinalityChecker"
file="CardinalityChecker.java" line="270" method="evaluateItem" />
     <at class="net.sf.saxon.functions.StringFn" file="StringFn.java"
line="54" method="evaluateItem" />
     <at class="net.sf.saxon.expr.ValueComparison"
file="ValueComparison.java" line="569" method="effectiveBooleanValue" />
     <at class="net.sf.saxon.expr.BooleanExpression"
file="BooleanExpression.java" line="182" method="effectiveBooleanValue" />
     <at class="net.sf.saxon.instruct.Choose" file="Choose.java" line="679"
method="processLeavingTail" />
     <at class="net.sf.saxon.expr.LetExpression" file="LetExpression.java"
line="557" method="processLeavingTail" />
     <at class="net.sf.saxon.instruct.Block" file="Block.java" line="556"
     <at class="net.sf.saxon.instruct.Template" file="Template.java"
line="203" method="applyLeavingTail" />
   </stack>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/507&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by fxp):
I can't reproduce the issue. I'm not sure this is related to create child
function. Please attach your metadata record to the patch.
Thanks.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/507#comment:1&gt;
Keywords: |
Comment(by aperi2007):
A retrieve the metadata from the log because I'm not able to get it from
GN.
Trying to open the metadata I have the same error.
The requested operation could not be performed. XPathException : A
So geto it from log of tomcat.
Add it to the ticket.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/507#comment:2&gt;
Keywords: |
this is the sequence to get the error. :slight_smile:
1. start with an empty db (postgres 9.0)
2. create a new metadata using the template "vector iso19139 (preferred)"
3. after create close the metadata.
4. re-open the metadata and choose the option: "other actions -> create
child"
5. after choose sample-group as target group
6. when appear the new metadata (child) to a "save and close"
at this point there is the error:
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/507#comment:3&gt;
Keywords: |
oops, retype:[[BR]]
1. start with an empty db (postgres 9.0) [[BR]]
[[BR]]
3. after create close the metadata. [[BR]]
child" [[BR]]
5. after choose sample-group as target group [[BR]]
6. when appear the new metadata (child) to a "save and close"[[BR]]
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/507#comment:4&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by fxp):
  * status: new => closed
  * resolution: => fixed
Comment:
r7754.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/507#comment:5&gt;
