[GeoNetwork-devel] [GeoNetwork opensource Developer website] #513: ConfigOverride Proposal
Reporter: jesseeichar | Owner: geonetwork-devel@…
Priority: major | Milestone: v2.7.0
Component: General | Version: v2.6.3
Keywords: |
In order to permit deployment of a Geonetwork instance to multiple
environments and assist in development this proposal adds the ability to
configure Geonetwork for multiple target deployment platforms (for
example, test and production) with a minimum of duplication and allow
configuration selection to be chosen via System properties or
!ServletConfig/Context parameters
see: [wiki:ConfigOverride]
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Changes (by jesseeichar):
* cc: jesseeichar (added)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513#comment:1&gt;
Keywords: |
Comment(by jesseeichar):
I have now correctly tested the patches against both 2.6.x and trunk.
The good patches are the last two:
http://trac.osgeo.org/geonetwork/attachment/ticket/513/override-config-
trunk.2.patch
config-2.6.x.patch
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513#comment:2&gt;
Keywords: |
Comment(by fxp):
Looks interesting Jesse.
Could it be possible to manage other types of configuration files which
may differ between deployment ? I was thinking of:
  * log4j.cfg
  * javax.xml.transform.!TransformerFactory
  * sql files (to set system settings maybe also ?)
  * print-config.yaml (not so important probably)
Is the file in input necessarily an XML document ?
I'm also not sure what's going to happen here
(http://trac.osgeo.org/geonetwork/wiki/proposals/ImprovedSecurityArchitecture)
but new configuration files will be added and should be align to existing
one probably.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513#comment:3&gt;
Keywords: |
Other file formats could be handled but they need to be structured files
if you want to be able to reliably add/remove/update. Also the
substitution takes place after launch so the transformer factory parameter
is likely not an easy one to update. However if the code is executed
early enough it might work.
So the types of files that can be updated are:
xml, json, yaml, etc...
sql files will be quite hard to do so I don't think I will to do that one.
But I think that I can add support for log4j as that is really common.
TransformerFactory is also hard but I can do a quick experiment to see if
that is possible
print-config.yaml ... I think a better place would be to patch the print
module so that the chosen config file can be controlled by system
parameters. It already respects init params so that does not need to be
updated.
In short I will add support for updating log4j before we apply this
proposal.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513#comment:4&gt;
Keywords: |
Comment(by fxp):
Replying to [comment:4 jesseeichar]:
True. I don't ask you to add that kind of support. I was more thinking
what is the best option for all (too many) configuration files we have.
2 others thoughts:
  * what happens if you have 2 GeoNetwork webapps ? the
jeeves.configuration.overrides.file system property is going to be shared
by the two (because System.getProperty is the first one called) and they
will share the configuration. For data and lucene directory (which could
be initialized by system property), we added variables depending on the
webapp name (see #352) - that's maybe not the best option anyway (for
example if no webapp context is set).
  * to better manage different environments configuration on the long-term,
maybe we should think of moving all configuration options outside the WEB-
INF folder and be able to load the conf using system or servlet property
like you've done (but loading the full conf for the target environment
instead of processing the default and overriding part of it) ?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513#comment:5&gt;
Keywords: |
Replying to [comment:5 fxp]:
files if you want to be able to reliably add/remove/update.
what is the best option for all (too many) configuration files we have. I
think that if this strategy works well we could expand it to include other
file types like json for the javascript configuration (which I think is a
better strategy than config-gui since it doesn't require a restart for the
changes to take place, but that is another discussion).
> 2 others thoughts:
If you look at the proposal A system property does not have to be used.
It is one of 3 options. The System property option is simply the easiest.
We also have ServletConfig and ServletContext, which can be injected by
the servletContainer. The ServletConfig is webapp specific so you could
use that strategy if you have multiple installations in the same
container.
term, maybe we should think of moving all configuration options outside
the WEB-INF folder and be able to load the conf using system or servlet
property like you've done (but loading the full conf for the target
environment instead of processing the default and overriding part of it)?
Well in someways I agree. I think it is important to control the
configuration through the servlet container. But the problem with that is
that there are LOTS of configuration parameters so at minimum you need a
way to set the defaults so that each deployment you don't need to declare
every parameter. That would not be any improvement over the current
situation. Also if all configuration is outside of geonetwork how can you
add new parameters without breaking an installation when they upgrade. It
is bad enough that new parameters are always added to the setting file
causing breakages (which is made acceptable by the migration scripts).
I think the solution of having the defaults written and committed to the
main repository and providing a way to override them is in fact quite a
maintainable solution.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513#comment:6&gt;
Keywords: |
I have updated the patches with the ability to control logging as well as
the configuration. see the proposal and javadocs for more details on that.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513#comment:7&gt;
Keywords: |
Comment(by fxp):
> (which I think is a better strategy than config-gui since it doesn't
require a restart for the changes to take place, but that is another
discussion).
You don't need to restart when updating config-gui.xml.
So we should probably apply similar strategy for existing properties.
Thanks.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513#comment:8&gt;
On Mon, May 30, 2011 at 10:20 AM, GeoNetwork opensource Developer
Keywords: |
Comment(by fxp):
discussion).
I wish I had known that before :stuck_out_tongue: But that is great!
Keywords: |
used. It is one of 3 options.
Thanks.
I think this is out of scope for this proposal but I agree.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513#comment:9&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords:
Changes (by craigj):
  * status: new => closed
  * resolution: => fixed
Comment:
Updated patch including override for profile configuration and shared
overrides applied to trunk in r7903.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/513#comment:10&gt;
