#527: Exception when sending multiple CSW update transactions to a geonetwork
record
Reporter: mbertrand | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: General | Version: v2.6.4
Keywords: |
When I attempt to send multiple CSW update
transactions to a record in Geonetwork in the same session, the first
update succeeds but all subsequent updates fail with an
ExceptionRecord: "Cannot process transaction: Raised exception while
searching metadata".
I am using a script from the wiki
(http://trac.osgeo.org/geonetwork/wiki/HowToDoCSWTransactionOperations)
which I modified to send an update transaction request for a particular
record several times in a row:
for n in range(0,2):
request = urllib2.Request(url_csw, xml_request, header_xml)
response = opener.open(request)
# CSW respons
xml_response = response.read()
print xml_response
Logging out and back in between requests doesn't help either.
But if I run the entire function twice (this time with only one update
request), then both updates succeed:
if __name__=="__main__":
gn_csw_transaction()
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/527>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
