#530: Deleting subelements n Point Of Contact in metadata editor
Reporter: josegar74 | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: General | Version: v2.6.4
Keywords: |
Possibly happens with other elements although I could reproduce it with
Point Of Contact.
Test: With default editor start removing the Point Of Contact subelements.
After some deletes is shown the attached window.
Log file contains an exception like:
2011-06-08 17:18:52,889 ERROR [jeeves.service] - (C) Exc :
java.lang.IllegalStateException: Element not found at ref = 96
2011-06-08 17:18:52,889 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
<message>Element not found at ref = 96</message>
<class>IllegalStateException</class>
<stack>
<at class="org.fao.geonet.kernel.DataManager" file="DataManager.java"
line="1477" method="deleteElementEmbedded" />
<at class="org.fao.geonet.services.metadata.DeleteElement"
file="DeleteElement.java" line="72" method="exec" />
<at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="238" method="execService" />
file="ServiceInfo.java" line="141" method="execServices" />
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="399" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="670" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="185" method="execute" />
file="JeevesServlet.java" line="98" method="doGet" />
<at class="javax.servlet.http.HttpServlet" file="HttpServlet.java"
line="707" method="service" />
line="820" method="service" />
</stack>
<request>
<language>en</language>
<service>metadata.elem.delete</service>
</request>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/530>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
