[GeoNetwork-devel] [GeoNetwork opensource Developer website] #531: Build / use maven profiles and resources filter
Reporter: fxp | Owner: geonetwork-devel@…
     Type: task | Status: new
Priority: minor | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Add profile support in maven pom.xml in order to:
  * update properties (eg. version number, xsl factory) in different files
(eg. config.xml, create-db-default.sql, server.prop)
  * easily create custom build (eg. INSPIRE one)
Usage :
  * mvn -Denv=dev
  * mvn -Denv=inspire
  * mvn -Denv=prod (default)
To do: apply to the installer build.xml and documentation ?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/531&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by fxp):
Committed revision 8062.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/531#comment:1&gt;
Keywords: |
Changes (by jesseeichar):
* cc: jesseeichar (added)
Comment:
This change breaks running jetty because the filters are only ran the war
is being built. I am looking into updating the jetty configuration
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/531#comment:2&gt;
Keywords: |
Comment(by jesseeichar):
One idea is to not do the filtering in the war configuration but instead:
  1. move files in webResources back to webapp
  1. do the filtering as part of resource processing phase which copies all
the webapp files to a directory in target
  1. update pom so that the webapp resources for both jetty and war are
found in the filtered directory.
I will try to do this and create a patch.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/531#comment:3&gt;
Keywords: |
I found a problem with my patch. the line:
                   <directory>src/main/webResources</directory>
must be changed to
                   <directory>${basedir}/src/main/webResources</directory>
and
                 <filter>src/main/filters/${env}.properties</filter>
must be changed to
<filter>${basedir}/src/main/filters/${env}.properties</filter>
(after the previous patch has been applied)
And while applying previous patch you will probably have to apply it from
web project as follows:
web> patch -p1 < 531_fix_for_jetty.patch
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/531#comment:4&gt;
      Type: task | Status: closed
Resolution: fixed | Keywords:
Changes (by Fxp):
  * status: new => closed
  * resolution: => fixed
Comment:
Revision: 8074
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/531#comment:5&gt;
