[GeoNetwork-devel] [GeoNetwork opensource Developer website] #532: New members should be added to a default group
Reporter: landry | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: General | Version: v2.6.0
Keywords: ldap, groups |
This is for GN 2.6.0, but i suppose it's still an issue in trunk.
I have my users stored in LDAP, so GN doesn't know them if they never
connected. So the first time they connect to GN and their user is created
in GN, they don't belong to any group, and the admin (me) needs to add
them to a group so that they can post a metadata.
So there should be the possibility to set a 'default group' where all new
users are when they connect.. or there should be the possibility to
set/retrieve the group name (or group id) in a LDAP attr, as it's done for
the profile.
So far, my workaround is to add them to the default group in my system
through cron and a sql req like 'insert into usergroups(userid,groupid)
select id as userid, 2 as groupid from users left join usergroups on
usergroups.userid=users.id where userid is null;'
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/532&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: ldap, groups
Changes (by josegar74):
  * status: new => closed
  * resolution: => fixed
Comment:
Changes in ldap/shibboleth to:
* Allow to configure default group for ldap and shibboleth users.
* Allow to configure group attribute to retrieve groups for users from
ldap/shibboleth. if the retrieved group doesn't exist in GeoNetwork then
is created.
If no default group is configured or no group attribute is provided in the
configuration, works as before.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/532#comment:1&gt;
