#533: batch import will lost link with parent met if choose to generate the UUID
Reporter: aperi2007 | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
using the r7850 version
I notice that try-ing a batch-import and setting
"Generate UUID for inserted metadata"
it lost the link between parent and child metadata.
infact it generate a new UUID also for <parentIdentifier>
but doing this it lost the link with the parent metadata that will have
another UUID (also it generated new)
I'm sure this feature will work correctly some trunk version ago...
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/533>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by aperi2007):
I tested again with r8040,
I can confirm the problem.
The option "Generate UUID for inserted metadata" break the link between
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/533#comment:1>
Keywords: |
I'm try-ing to understand how to resolve the ticket #533.
but I don't know so well the geonetwork code. I'm try to find what java
file is the involved file in the
batch import and generate a new UUID for every metadata imported, so I
can't try to develope a patch.
I guess a solution could be to change the function use to generate the
UUID,
instead to use the "UUID.RandomUUID()" function that generate a completely
randomic UUID.
I think should be better to use the
"UUID.fromString(stringa-name)" function
that generate an UUID using a string .
Using as string-name the actually FileIdentifier to be overlapped, this
should be grant the maintaining of the link between parent and child with
the new UUID generated.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/533#comment:2>
Priority: major | Milestone: v2.8.0
Keywords: |
Changes (by ianwallen):
* milestone: v2.7.0 => v2.8.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/533#comment:3>
