#569: Using Stop words can construct illegal phrases
Reporter: jesseeichar | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: General | Version: v2.6.3
Keywords: |
Suppose you make the phrase query:
the biggest
if you are using english stop words then 'the' is removed and the new
phrase is ' biggest' (notice the space before biggest). Since spaces are
removed when a metadata is indexed the phrase cannot find a match.
The solution I came up with is to do a check when constructing phrases to
ensure that a term being added to the phrase has content, if not it will
be discarded.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/569>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
