#580: Add ability to specify overrides for XML files loaded by XmlFile class
Reporter: jesseeichar | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: General | Version: v2.6.3
Keywords: |
The main benefit of this patch is to make it possible to declare overrides
for files like config-gui.xml. WIth the addition of this patch, overrides
can be used to configure all xml files loaded by services (guiServices for
example). So you can override strings.xml, config-gui.xml, countries.xml,
etc...
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/580>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by jesseeichar):
Note: I am working towards being able to reduce the number of settings
used by the maven filters. I will shortly follow up with an option to
override lines in the sql configuration files.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/580#comment:1>
Type: defect | Status: closed
Priority: major | Milestone: v2.7.0
Resolution: fixed | Keywords:
Changes (by fxp):
* status: new => closed
* version: v2.6.3 =>
* resolution: => fixed
* milestone: v2.6.5 => v2.7.0
Comment:
see also #589
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/580#comment:2>
