#588: Index / Add metadata related resources content analysis for full text
search
Reporter: fxp | Owner: geonetwork-devel@…
Priority: major | Milestone: Future release
Component: General | Version:
Keywords: |
The idea is to analyse related resource defined in the metadata record in
order to improve search results. For example, if a WFS layer is linked to
a metadata record, then the !GetFeature response could be analyzed and
index and user could search using feature attributes like names, ...
Another interesting case is when you link the documentation of a layer in
the metadata, the content of the documentation is also indexed.
Add a service to:
* analyze a metadata record for related resources (eg. PDF, WFS
!GetFeature, !OpenOffice, webpage)
* parse the related resources
* add content to the full text search field (ie. any)
Metadata analysis phase is based on an XSLT. Main idea is to grab gmd:URL
elements. The analysis doesn't need to define the content type which is
usually automatically detected by the !AutoDetectParser.
Document parser is based on Apache Tika project: http://tika.apache.org/.
It supports different formats (http://tika.apache.org/0.9/formats.html)
and could be used for XML based content like KML, WFS !GetFeature response
for example.
As a first approach, the service is run manually:
* to analyze the record and return a report on related ressources
* metadata.index.extra?uuid=894ab2ff-e16c-477c-be7a-009f5da8289b
<response>
<resources>
<file type="xml"
url="http://services.sandre.eaufrance.fr/geo/ouvrage?service=WFS&version=1.0.0&REQUEST=DescribeFeatureType&TYPENAME=REPOM"/>
<file type="xml"
url="http://services.sandre.eaufrance.fr/geo/ouvrage?service=WFS&version=1.0.0&REQUEST=GetFeature&TYPENAME=REPOM"/>
<file type="pdf"
url="/home/work/documentation/gis/data/env/landcover.pdf"/>
<file type="unknown"
url="http://www.eea.europa.eu/publications/COR0-landcover/at_download/file"/>
</resources>
</response>
* to analyze and parse the related resources returning the extracted
metadata and content (see screenshot)
009f5da8289b&parse=true
* to analyze, parse and re-index the document with the extracted content
added to the full text search field.
009f5da8289b&parse=true&index=true
Note:
* An update of the record will remove the extracted content. The analysis
needs to be runned again.
* Document parsing could take more or less time to download and/or parse
according to its location and size.
* Index size will increase
* Users may not understand why a metadata is found because the search
criteria comes from the related resources and not the metadata document
itself.
Improvements:
* Add a GUI
* Add a flag to the metadata where the editor could define if extra
content should be added when the record is indexed ?
* Add a background task to do this automatically on all records ?
References:
* Old discussion about KML and WFS indexing http://osgeo-
org.1803224.n2.nabble.com/Related-document-indexing-eg-kml-and-wfs-
indexing-tt3708088.html
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/588>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
