#601: CSW startPosition + maxRecords does not work (Simple fix)
Reporter: jesseeichar | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: General | Version: v2.6.3
Keywords: |
Doing a CSW request of the type: results_with_summary if the startPosition
is not == 1 the wrong result is returned. Here are some requests and
results:
Request (works correctly):
<csw:GetRecords xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
service="CSW" version="2.0.2" startPosition="1" maxRecords="10"
resultType="results_with_summary">
<csw:Query typeNames="csw:Record">
<csw:Constraint version="1.1.0">
<Filter xmlns="http://www.opengis.net/ogc"
xmlns:gml="http://www.opengis.net/gml"/>
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
Response: (It is correct)
<csw:GetRecordsResponse xmlns:csw="http://www.opengis.net/cat/csw/2.0.2"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xsi:schemaLocation="http://www.opengis.net/cat/csw/2.0.2
http://schemas.opengis.net/csw/2.0.2/CSW-discovery.xsd">
<csw:SearchStatus timestamp="2011-09-06T10:49:50" />
<geonet:Summary xmlns:geonet="http://www.fao.org/geonetwork"
count="3456" type="local" hitsusedforsummary="1000">
[snip...]
</geonet:Summary>
<csw:SearchResults numberOfRecordsMatched="3456"
numberOfRecordsReturned="10" elementSet="summary" nextRecord="11">
[snip...]
</csw:SearchResults>
</csw:GetRecordsResponse>
Request with startPosition == 11:
<?xml version="1.0"?>
service="CSW" version="2.0.2" resultType="results_with_summary"
startPosition="11" maxRecords="10" >
</csw:Constraint>
</csw:Query>
</csw:GetRecords>
Response (incorrect because no records are returned):
<csw:SearchStatus timestamp="2011-09-06T10:51:54" />
[snip...]
</geonet:Summary>
numberOfRecordsReturned="0" elementSet="summary" nextRecord="11" />
Fix is attached
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/601>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
