[GeoNetwork-devel] [GeoNetwork opensource Developer website] #604: MetadataURL links are not followed for FeatureTypes in WFS or Coverages in WCS
WCS
Reporter: rmcaleer | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: Future release
Component: General | Version: v2.6.4
Keywords: WFS, WCS, Harvesting, Metadata, MetadataURL |
Steps to reproduce:
* Go to 'Administration->Harvesting Management' in Geonetwork
* Add an OGC Web Service
** Select one of the WFS or WCS options
** Select 'Create metadata for layer elements using MetadataURL attributes
(if existing, if not use GetCapabilities).' for the 'Type of Import'
* Go back to the Harvesting Management page, select the added OGC Service
and 'Run' it to start harvesting.
There's no easy way to tell if it follows the MetadataURL links. I set up
a remote debug session to my Geonetwork install from eclipse and put a
breakpoint in the org.fao.geonet.kernel.harvest.harvester.ogcwxs.Harvester
class in the addLayerMetadata method. On line 505 there is the following
check:
if (params.useLayerMd && params.ogctype.substring(0,3).equals("WMS")) {
The code within this if block does the parsing of the MetadataURL element,
but unless it's a WMS this section is never called and there is no other
code to parse MetadataURL elements if it's a WCS or WFS.
* Note: Filing as a defect (rather than enhancement) since I haven't found
anywhere in the app or documentation that suggests MetadataURLs aren't
supported for WFS & WCS (so the implication is that they are).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/604&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
