#612: XML files loaded by GeoNetwork may not be in UTF-8 charset and may fail to
load
Reporter: simonp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Some XML files have not UTF-8 chars in them - usually WINDOWS-1252 because
these are often pasted into metadata fields from Microsoft apps. The user
doesn't realize that the XML file is then no longer UTF-8 and receives
strange errors such as 'Error on line 118 of document file:/home/simon
/bioreg-test/caab37020028.xml: Invalid byte 2 of 3-byte UTF-8 sequence'
when they try to load the XML file into GeoNetwork.
GeoNetwork needs to detect the character set of file content and convert
to UTF-8 before attempting to load. Can do this using charset detectors
often used in browsers. There is a patch attached which adds the mozilla
juniversalcharsetdetector to the loadFile method in the Jeeves
utils/Xml.java class. A system property
(jeeves.filecharsetdetectandconvert) must be set to enable charset
detection and conversion (it is disabled by default or if missing).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/612>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
