[GeoNetwork-devel] [GeoNetwork opensource Developer website] #657: On windows 7, the menu Item “Uninistaller” does not launch the uninstaller
Reporter: ByronCinNZ | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version: v2.6.3
Keywords: |
After installing GeoNetwork on Windows 7 64 bit systems, I have noticed
that shortcuts in Start->GeoNetwork ("Uninstaller") do not launch the
right application. I have researched this and it seems to be a bug in the
IZPack installer with windows 7 64bit.
The argument “command Line” does not seem to find the correct value for
“target” at certain situations. The published patch for 64 bit systems I
found did not work. My solution was to leave the “commandLine” blank and
move its value to “target” as follows:
Instead of :
target =”java”
commandLine==”-jar "$INSTALL_PATH/Uninstaller/uninstaller.jar" ”
I used:
target =”java -jar "$INSTALL_PATH/Uninstaller/uninstaller.jar" ”
commandLine==””
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/657&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by pvgenuchten):
reproduced on Win7x64
- Uninstall contains target='...../license.html' -jar ...
- However in shortcut-definition, target for this shortcut is 'java',
target in previous item is '.../license.html'
Tried to reproduce in WinXPx32, but error did not occur.
Seems like a bug in IZPack, did not find any similar behaviour on their
website
Workaround might be, put uninstall shortcut before license shortcut
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/657#comment:1&gt;
Priority: major | Milestone: v2.8.0
Keywords: |
Changes (by ianwallen):
  * milestone: v2.7.0 => v2.8.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/657#comment:2&gt;
