[GeoNetwork-devel] [GeoNetwork opensource Developer website] #660: Virtual CSW endpoints
Reporter: josegar74 | Owner: geonetwork-devel@…
Priority: major | Milestone: v2.7.0
Component: General | Version: v2.6.3
Keywords: |
Add the capability to have custom CSW entry points that applies extra
criteria to the CSW request.
A new CSW service entry point is defined using the following syntax:
<service name="csw-with-my-filter">
        <class name=".services.main.CswDispatcher" >
                <param name="filter" value="+inspirerelated:on
+themekey:environment"/>
        </class>
</service>
The "filter" parameter value is the filter to apply to Lucene query using
Lucene query syntax (
http://lucene.apache.org/java/2_4_0/queryparsersyntax.html). Allows OR and
AND operators.
Adding new services require a restart of the application.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/660&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Description changed by josegar74:
Old description:
       </class>
</service>
and AND operators.
New description:
        </class>
</service>
http://lucene.apache.org/java/2_9_1/queryparsersyntax.html). Allows OR and
AND operators.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/660#comment:1&gt;
Keywords: |
Comment(by josegar74):
Added updated patch including updated manual
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/660#comment:2&gt;
Keywords: |
Updated patch fixing service end-points in capabilities document and
documentation section on how to configure using overrides feature
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/660#comment:3&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords:
Changes (by josegar74):
  * status: new => closed
  * resolution: => fixed
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/660#comment:4&gt;
