[GeoNetwork-devel] [GeoNetwork opensource Developer website] #666: Default ANZLIC Metadata characterSet generates a Schematron error
Reporter: murrayh | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: minor | Milestone: Future release
Component: General | Version:
Keywords: ANZLIC Metadata characterSet Schematron |
Version: !GeoNetwork 2.7 svn rev 8285 schemaPlugins svn rev 8406.
When you create an ANZLIC record in !GeoNetwork, the following Metadata
characterSet is generated:
  <gmd:MD_CharacterSetCode codeListValue="utf8"
codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#MD_CharacterSetCode&quot;/&gt;
The Schematron does not like that characterSet:
  ( failed2 errors) checkCodeList
      (1) Unable to find the specified codeList document or
!CodeListDictionary node.
      (2) codeListValue is not in the specified codeList.
This characterSet has been considered valid in previous versions of
!GeoNetwork.
You can work around this issue by manually editing the XML and changing
the characterSet to:
codeList="http://asdd.ga.gov.au/asdd/profileinfo/gmxCodelists.xml#MD_CharacterSetCode&quot;&gt;utf8&lt;/gmd:MD\_CharacterSetCode&gt;
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/666&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Comment(by murrayh):
Note that there are a lot of existing ANZLIC records using the first
characterSet definition (that we may harvest from older versions of
!GeoNetwork into 2.7).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/666#comment:1&gt;
And this issue also affects MCP records that we have harvested.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/666#comment:2&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: ANZLIC Metadata characterSet Schematron
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed by adding mappings for the urls used in these codelist elements to
the oasis catalog file for these schemas. Svn rev 8496 for details.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/666#comment:3&gt;
  Priority: minor | Milestone: v2.7.0
Changes (by ianwallen):
  * milestone: Future release => v2.7.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/666#comment:4&gt;
