#683: Editing / Ajax mode / add attribute with namespace support
Reporter: fxp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: Future release
Component: General | Version:
Keywords: |
When adding an attribute having a namespace using Ajax mode, an exception
is thrown :
2011-11-29 20:24:57,519 INFO [jeeves.service] - Dispatching :
metadata.elem.add.new
2011-11-29 20:24:57,519 DEBUG [jeeves.service] - -> parameters are :
<request>
<child>geonet:attribute</child>
<id>94</id>
<ref>116</ref>
<name>xlink:role</name>
<_dc>1322594697508</_dc>
</request>
2011-11-29 20:24:57,519 ERROR [jeeves.service] - Exception when executing
service
2011-11-29 20:24:57,519 ERROR [jeeves.service] - (C) Exc :
org.jdom.IllegalNameException: The name "xlink:role" is not legal for
JDOM/XML attributes: Attribute names cannot contain colons.
2011-11-29 20:24:57,520 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
<message>The name "xlink:role" is not legal for JDOM/XML attributes:
Attribute names cannot contain colons.</message>
<class>IllegalNameException</class>
<stack>
<at class="org.jdom.Attribute" file="Attribute.java" line="361"
method="setName" />
<at class="org.jdom.Attribute" file="Attribute.java" line="228"
method="<init>" />
<at class="org.jdom.Attribute" file="Attribute.java" line="252"
method="<init>" />
<at class="org.fao.geonet.services.metadata.AjaxEditUtils"
file="AjaxEditUtils.java" line="314" method="addElementEmbedded" />
The issue happens when turning on xlink attributes editing for example.
Probably a method similar to applyChangesEmbedded using the
COLON_SEPARATOR should be used.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/683>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
