#684: Thesaurus manager failed to load .xml files
Reporter: fxp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: minor | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Error is :
2011-11-30 10:12:43,216 ERROR [jeeves.service] - Exception when executing
service
2011-11-30 10:12:43,217 ERROR [jeeves.service] - (C) Exc :
java.lang.StringIndexOutOfBoundsException: String index out of range: -1
2011-11-30 10:12:43,217 DEBUG [jeeves.service] - Raised exception while
executing service
<error id="error">
<message>String index out of range: -1</message>
<class>StringIndexOutOfBoundsException</class>
<stack>
<at class="java.lang.String" file="String.java" line="1937"
method="substring" />
<at class="org.fao.geonet.kernel.Thesaurus" file="Thesaurus.java"
line="147" method="buildThesaurusKey" />
line="109" method="getKey" />
<at class="org.fao.geonet.kernel.ThesaurusManager"
file="ThesaurusManager.java" line="159" method="addThesaurus" />
<at class="org.fao.geonet.services.thesaurus.Upload"
file="Upload.java" line="237" method="UploadThesaurus" />
file="Upload.java" line="187" method="upload" />
file="Upload.java" line="84" method="exec" />
<at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="230" method="execService" />
file="ServiceInfo.java" line="139" method="execServices" />
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="408" method="dispatch" />
</stack>
<request>
<language>en</language>
<service>xml.thesaurus.upload</service>
</request>
</error>
Workaround : rename thesaurus to .rdf
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/684>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Keywords: |
Comment(by heikki):
I think it should be such that any file extension is supported, it should
not matter. If the contents are can't be processed correctly than some
exception will occur.
Maybe with one exception on startup, for example the extension ".do-not-
load-on-startup", so we could put example thesauri in their correct
location that we don't want to be loaded automatically on start up. These
could be still loaded manually by ad Administrator later.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/684#comment:1>
Keywords: |
Comment(by fxp):
At least support XML file (Committed revision 8474).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/684#comment:2>
Priority: minor | Milestone: Future release
Keywords: |
Changes (by fxp):
* milestone: v2.7.0 => Future release
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/684#comment:3>
