[GeoNetwork-devel] [GeoNetwork opensource Developer website] #691: Keyword selection / add keyword using gmx:Anchor instead of gco:CharacterString
gco:CharacterString
Reporter: fxp | Owner: geonetwork-devel@…
Priority: major | Milestone: Future release
Component: General | Version:
Keywords: |
In some metadata profiles, keywords are created using gmx:Anchor instead
of gco:CharacterString. It needs basic support for Anchor (See #681) and
changes on !KeywordBean#getComplexIso19139Elt which is called before
adding keywords.
Example:
<gmd:descriptiveKeywords>
         <gmd:MD_Keywords>
                 <gmd:keyword>
                         <gmx:Anchor
xlink:href="http://www.seadatanet.org/urnurl/SDN:P021::ATVS&quot;&gt;Atmospheric
visibility and transparency</gmx:Anchor>
                 </gmd:keyword>
                 <gmd:keyword>
                         <gmx:Anchor
xlink:href="http://www.seadatanet.org/urnurl/SDN:P021::SAGE&quot;&gt;Sediment
age</gmx:Anchor>
                 </gmd:keyword>
                 <gmd:type>
                         <gmd:MD_KeywordTypeCode
codeList="http://www.seadatanet.org/urnurl/codelists.xml#MD_KeywordTypeCode&quot;
codeListValue="parameter"
codeSpace="http://www.seadatanet.org/urnurl/&quot;&gt;parameter&lt;/gmd:MD\_KeywordTypeCode&gt;
                 </gmd:type>
                 <gmd:thesaurusName>
                         <gmd:CI_Citation>
                                 <gmd:title>
                                         <gco:CharacterString>BODC
Parameter Discovery Vocabulary</gco:CharacterString>
                                 </gmd:title>
                                 <gmd:alternateTitle>
<gco:CharacterString>P021</gco:CharacterString>
                                 </gmd:alternateTitle>
                                 <gmd:date>
                                         <gmd:CI_Date>
                                                 <gmd:date>
<gco:Date>2009-06-05</gco:Date>
                                                 </gmd:date>
                                                 <gmd:dateType>
<gmd:CI_DateTypeCode
codeList="http://www.isotc211.org/2005/resources/Codelist/gmxCodelists.xml#CI_DateTypeCode&quot;
codeListValue="revision"
codeSpace="ISOTC211/19115">revision</gmd:CI_DateTypeCode>
                                                 </gmd:dateType>
                                         </gmd:CI_Date>
                                 </gmd:date>
                                 <gmd:edition>
<gco:CharacterString>41</gco:CharacterString>
                                 </gmd:edition>
                                 <gmd:identifier>
                                         <gmd:MD_Identifier>
                                                 <gmd:code>
<gco:CharacterString>http://www.seadatanet.org/urnurl/SDN:P021&lt;/gco:CharacterString&gt;
                                                 </gmd:code>
                                         </gmd:MD_Identifier>
                                 </gmd:identifier>
                         </gmd:CI_Citation>
                 </gmd:thesaurusName>
         </gmd:MD_Keywords>
</gmd:descriptiveKeywords>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
gco:CharacterString
      Type: enhancement | Status: closed
Resolution: fixed | Keywords:
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Fixed in commit #9241
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691#comment:1&gt;
gco:CharacterString
  Priority: major | Milestone: v2.7.0
Changes (by ianwallen):
  * milestone: Future release => v2.7.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691#comment:2&gt;
gco:CharacterString
      Type: enhancement | Status: reopened
Component: General | Version: v2.8.0RC1
Resolution: | Keywords:
Changes (by mcoudert):
  * status: closed => reopened
  * version: => v2.8.0RC1
  * resolution: fixed =>
Comment:
Keywords selection in the advanced GUI, in the editor, leads to create
keywords using gmx:Anchor... Is it an expected behavior in 2.8.0-RC1?
I'm wondering how gmx:Anchor elements are supported in that version
because it breaks search on keywords (i.e. computing extent from
keywords).
Thanks in advance for your reply
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691#comment:3&gt;
gco:CharacterString
Comment(by simonp):
I think the idea behind this is that if you going to select a keyword from
the thesaurus then you need to be able to recover the exact keyword from
the thesaurus - to do this you need the id of that keyword in the
thesaurus otherwise you can't really know which one it is (reliably that
is) - to do that you would need a gmx:Anchor (or some other substitute)
rather than a gco:CharacterString. In what way does it break the computing
extent from keywords process (apart from the obviously allowing for both
gco:CharacterString and gmx:Anchor)? Just looking at the process xslt I
can't see that it would be difficult to make it work with either?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691#comment:4&gt;
gco:CharacterString
Comment(by fxp):
I think that should be a profile configuration. I'm working on a proposal
for that which extends the ideas described in the registers proposal by
providing a way to use a thesaurus selection for making any ISO elements
by defining:
  * association: eg. thesaurus A could be used to define ISO element of
type gmd:descriptiveKeywords (but could be other like gmd:extent)
  * transformation: eg. gmd:descriptiveKeywords could be added as XLinks,
gco:CharacterString, gmx:Anchor
The configuration could be made on a per profile basis and the type of
transformation will be available as a choice in the thesaurus selection
popup (instead of having the xlink or not only option as currently).
The configuration would look like this:
<!-- All thesaurus for gmd:descriptiveKeywords -->
<registerAssociation registerId="local://thesaurus/*"
element="gmd:descriptiveKeywords"/>
<!-- 3 conversions from SKOS to ISO -->
<!-- Add keyword as ISO19139 fragments -->
<registerTransformation element="gmd:descriptiveKeywords"
xslTpl='skos2gmd_keywords'/>
<!-- Add keyword as ISO19139 fragments using gmx:Anchor -->
xslTpl='skos2gmd_keywords_with_anchor'/>
<!-- Add keyword using an Xlink -->
xslTpl='skos2gmd_keywords_with_xlink'/>
I'll write a draft proposal on it this month probably.
For 2.8.x, it's maybe better to keep gco:CharacterString by default ? as
gmx:Anchor is probably not so well known for the general user.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691#comment:5&gt;
gco:CharacterString
Comment(by mcoudert):
Yep Simon and François, I fully understand the need or the use of the
gmx:Anchor for keywords but my concern is more focused on coming 2.8
version where defaults gmx:Anchor elements break the computing extent from
keywords process.
Can we update the process stylesheet to support default gmx:Anchor or
maybe can we set back gco:CharacterString as default element when creating
keywords for the 2.8.x branch?
Any thoughts...
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691#comment:6&gt;
gco:CharacterString
Comment(by simonp):
I'll happily update the process stylesheet to handle both (don't think
this is a big task). Also, for the time being (until we get a per profile
config as described above) maybe we could config this as a global option -
default is the kind of stupid old gco:Char thing but if config is set then
Anchors are used. Certainly critical for Anchors to be supported for use
cases here where we sometimes have > 10 thesauri in use....
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691#comment:7&gt;
gco:CharacterString
  Priority: major | Milestone: v2.8.0 RC2
  * milestone: v2.7.0 => v2.8.0 RC2
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691#comment:8&gt;
gco:CharacterString
  * milestone: v2.8.0 RC2 => v2.8.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691#comment:9&gt;
gco:CharacterString
Comment(by fxp):
Here is a mechanism which could handle !CharacterString, Anchor and XLink
addition mode using a widget in the editor instead of the popup. See
http://www.youtube.com/watch?v=prSRnnUmyDA
Feedback welcomed.
This change could be added to 2.9.x I think.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/691#comment:10&gt;
