[GeoNetwork-devel] [GeoNetwork opensource Developer website] #719: Widgets / Handle gco:nilReason attribute in editor
Reporter: fxp | Owner: geonetwork-devel@…
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Add the capability to set the value of gco:nilReason attribute from the
editor.
Currently !GeoNetwork add @gco:nilReason='missing' when a
gco:CharacterString is empty (using update-fixed-info).
In some situation, editor may want to use other codelist values for this
attributes (eg. inapplicable).
UC :
  * Set the value to inapplicable for version format
  * Set the value to inapplicable to gmd:pass element in a DQ report
Changes :
  * Add in editor toolbar a menu to display attribute controls (default
hidden to not overload the editor)
  * Simplify attribute editing section (see screenshot)
  * Remove gco:nilReason to editor exception in edit XSL
This changes are fully compatible with #405.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/719&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
