#731: CSW DC output should display valid CRS URN
Reporter: tomkralidis | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: General | Version: v2.6.4
Keywords: |
CSW DC output has the following snippet for spatial representation:
<ows:BoundingBox crs="urn:ogc:def:crs:::WGS 1984">
<ows:LowerCorner>-52.03125 21.796875</ows:LowerCorner>
<ows:UpperCorner>-106.875 54.140625</ows:UpperCorner>
</ows:BoundingBox>
Is {{{urn:ogc:def:crs:::WGS 1984}}} a valid CRS? Since GN controls this
output, it would be valuable to output a known and valid CRS (whether it's
a EPSG code, URN, etc.), which honours axis order.
Examples:
<ows:BoundingBox crs="urn:ogc:def:crs:EPSG:6.11:4326">
<ows:LowerCorner>miny minx</ows:LowerCorner>
<ows:UpperCorner>maxy maxx</ows:UpperCorner>
</ows:BoundingBox>
<ows:BoundingBox crs="EPSG:4326">
<ows:LowerCorner>minx miny</ows:LowerCorner>
<ows:UpperCorner>maxx maxy</ows:UpperCorner>
</ows:BoundingBox>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/731>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
Component: Catalog server | Version: v2.6.4
Keywords: |
Changes (by tomkralidis):
* component: General => Catalog server
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/731#comment:1>
Keywords: |
Comment(by tomkralidis):
Update: the WGS 1984 comes from the ISO document which was inserted into
the GN catalog via CSW Transaction (Insert). I updated the ISO document
with the following snippet:
<gmd:RS_Identifier>
<gmd:code>
<gco:CharacterString>4326</gco:CharacterString>
</gmd:code>
<gmd:codeSpace>
<gco:CharacterString>EPSG</gco:CharacterString>
</gmd:codeSpace>
</gmd:RS_Identifier>
at which point the CRS is outputted correctly:
<ows:BoundingBox crs="urn:ogc:def:crs:EPSG::4326">
</ows:BoundingBox>
However a./ the axis order is off and b./ the x coordinates are swapped
(related ticket #730).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/731#comment:2>
Keywords: |
FYI the metadata above was generated from the GN UI, which allows 'WGS
1984' as a projection when specifying the bounding coordinates of the
metadata, so I'm guessing this should be updated in the UI area.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/731#comment:3>
