#739: Importing sample data with postgis doesn't work correctly with new
indexmetadatatask (from svn commit 8577)
Reporter: simonp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Using trunk subversion revision 8586
Some sample data will load, others fail with NPE:
2012-01-18 16:10:52,453 ERROR [geonetwork.datamanager] - The metadata
document index with id=3 is corrupt/invalid - ignoring it. Error: null
java.lang.NullPointerException
at org.fao.geonet.kernel.DataManager.indexMetadata(DataManager.java:407)
at
org.fao.geonet.kernel.DataManager$IndexMetadataTask.run(DataManager.java:327)
at
java.util.concurrent.ThreadPoolExecutor$Worker.runTask(ThreadPoolExecutor.java:886)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:908)
at java.lang.Thread.run(Thread.java:619)
Curiously everything works fine with h2
The NPE seems to occur because the metadata is not actually retrieved from
the database (could be because the IndexMetadataTask has opened another
Dbms channel and doesn't have access to the records it wants because they
haven't been committed?).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/739>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
