[GeoNetwork-devel] [GeoNetwork opensource Developer website] #756: Valid metadata fails to import if it has spurious namespace declaration
Reporter: heikki | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: import metadata |
The attached file, which is a valid ISO19139 metadata, cannot be imported
in GN trunk. You get the message "Root Element Not Set".
If you remove the csw namespace declaration from the root element, the
problem disappears.
GeoNetwork should be able to import all valid ISO19139 metadata.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/756&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: import metadata
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Change base iso19139 schema autodetect rule to use the root element
gmd:MD_Metadata
and thus trap this record as belonging to iso19139
Schema autodetect rules are evaluated in order of how specific they are:
- first are those rules that search for an element + value or attribute +
value
- then the root element rules are evaluated
- then a namespace match is attempted
- finally, if all of the above fails, the default schema config.xml value
is used
It's appropriate that base schemas like iso19139 use a root element rule
and profiles of iso19139 use either element/attribute search if they don't
change the root element or
their own separate root element rule if they do change the root element
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/756#comment:1&gt;
