[GeoNetwork-devel] [GeoNetwork opensource Developer website] #766: Build broken in trunk
Reporter: heikki | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: blocker | Milestone: v2.7.0
Component: Installer | Version:
Keywords: |
when you try to build an installer using the trunk code, the process fails
with this output:
C:\source\geonetwork\installer>ant
Buildfile: build.xml
setProperties:
    [delete] Deleting directory C:\source\geonetwork\.props
     [mkdir] Created dir: C:\source\geonetwork\.props
[propertyfile] Updating property file:
C:\source\geonetwork\web\src\main\webapp\WEB-INF\server.prop
      [copy] Copying 1 file to C:\source\geonetwork\.props
thesaurusDownload:
       [get] Getting:
https://geonetwork.svn.sourceforge.net/svnroot/geonetwork/utilities/gemet/thesauri/gemet.rdf
       [get] To: C:\source\geonetwork\web\target\thesauri\gemet.rdf
       [get] Getting:
/inspire-service-taxonomy.rdf
       [get] To: C:\source\geonetwork\web\target\thesauri\inspire-service-
taxonomy.rdf
       [get] Getting:
/inspire-theme.rdf
       [get] To: C:\source\geonetwork\web\target\thesauri\inspire-theme.rdf
inspireDbSettings:
      [copy] Copying 1 file to C:\source\geonetwork\web\target\inspire
BUILD FAILED
C:\source\geonetwork\installer\build.xml:66: replacefilter doesn't support
the nested "replacetoken" element.
Total time: 25 seconds
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/766&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Priority: major | Milestone: v2.7.0
Keywords: |
Changes (by heikki):
  * priority: blocker => major
Comment:
Upgraded my ant from 1.7.1 to 1.8.2 which solved the problem.
Lowered prio of this ticket.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/766#comment:1&gt;
      Type: defect | Status: closed
Resolution: invalid | Keywords:
Changes (by ianwallen):
  * status: new => closed
  * resolution: => invalid
Comment:
A lot has changed in the build process - marking invalid
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/766#comment:2&gt;
