#79: CSW / BooleanQuery$TooManyClauses
Reporter: Fxp | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: minor | Milestone:
Component: Catalog server | Version:
Keywords: CSW |
CatalogSearcher and LuceneSearcher should provide the same results:
BooleanQuery.setMaxClauseCount(16384);
CSW search return exception:
"org.apache.lucene.search.BooleanQuery$TooManyClauses: maxClauseCount is
set to 1024"
See discussion:
http://www.nabble.com/CSW-BooleanQuery%24TooManyClauses-td20186713.html
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/79>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
Type: defect | Status: closed
Resolution: wontfix | Keywords: CSW
Changes (by fxp):
* status: new => closed
* resolution: => wontfix
Comment:
We can't provide a testing scenario to reproduce the issue with trunk now.
The problem should occur when having lot of metadata records and a bigger
index.
BooleanQuery.setMaxClauseCount "Set the maximum number of clauses
permitted per BooleanQuery. Default value is 1024."
If CSW user get this error, we should probably increase MaxClauseCount in
CatalogSearcher.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/79#comment:1>
Reporter: Fxp | Owner: geonetwork-devel@…
Priority: major | Milestone:
Changes (by iburago):
* priority: minor => major
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/79#comment:2>
