[GeoNetwork-devel] [GeoNetwork opensource Developer website] #813: extent parameter in EPSG:4326 whatever the map's projection is
Reporter: jeanpommier | Owner: geonetwork-devel@…
Priority: trivial | Milestone: v2.7.0
Component: General | Version:
Keywords: extent projections |
In the widget API, one can define the initial map extent using the
'extent' parameter. In case someone uses a map projection different than
EPSG:4326 (eg mercator), it would nevertheless be easier to define the
extent using geographic coordinates.
This proposal reprojects the extent (in geographic) to the map's
projection, whatever it is.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/813&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Priority: trivial | Milestone: v2.9.0
Changes (by ianwallen):
  * milestone: v2.7.0 => v2.9.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/813#comment:1&gt;
