[GeoNetwork-devel] [GeoNetwork opensource Developer website] #835: Thesaurus reference not included in thesaurusName block when Thesaurus picker used to insert keywords
Reporter: simonp | Owner: geonetwork-devel@…
Priority: minor | Milestone: v2.7.0
Component: General | Version:
Keywords: |
A reference to the thesaurus should be available for two reasons:
- allows revisit by thesaurus picker to be coded (see ticket #711)
- users should be able to access the entire thesaurus if required
Suggested fix is to change KeywordBean to encode thesaurus reference in
gmd:otherCitationDetails/gmx:FileName and thesaurus id as id attribute on
gmd:thesaurusName/gmd:CI_Citation *and* don't process gmx:FileName in
updated-fixed-info.xsl when ancestor CI_Citation has a geonetwork
thesaurus in its id attribute.
eg. of a thesaurusName block added with keywords:
<gmd:thesaurusName>
   <gmd:CI_Citation
id="geonetwork.thesaurus.register.theme.bc44a748-f1a1-4775-9395-a4a6d8bb8df6">
     <gmd:title>
       <gco:CharacterString>THESAURUS NAME</gco:CharacterString>
     </gmd:title>
     <gmd:date gco:nilReason="unknown"/>
     <gmd:otherCitationDetails>
       <gmx:FileName
src="http://localhost:8080/geonetwork/srv/eng/metadata.show?uuid=bc44a748-f1a1-4775-9395-a4a6d8bb8df6&quot;&gt;register\.theme\.bc44a748\-f1a1\-4775\-9395\-a4a6d8bb8df6&lt;/gmx:FileName&gt;
     </gmd:otherCitationDetails>
   </gmd:CI_Citation>
</gmd:thesaurusName>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/835&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Comment(by fxp):
A reference to the thesaurus could be created using gmx:Anchor like this
(Not sure it's better than gmx:FileName):
     <gmd:title>
       <gmx:Anchor
xlink:href="http://localhost:8080/geonetwork/srv/eng/geonetwork/srv/eng/thesaurus.download?ref=geonetwork.thesaurus.register.theme.bc44a748-f1a1-4775-9395-a4a6d8bb8df6&quot;&gt;THESAURUS
NAME</gmx:Anchor>
     </gmd:title>
But this links to the RDF file. Maybe a link to the register view mode is
expected ? In that case:
     <gmd:title>
       <gmx:Anchor
xlink:href="http://localhost:8080/geonetwork/?uuid=bc44a748-f1a1-4775-9395-a4a6d8bb8df6&quot;&gt;THESAURUS
NAME</gmx:Anchor>
     </gmd:title>
       <gmx:Anchor
NAME (SKOS format)</gmx:Anchor>
I would also replace
  * http://localhost:8080/geonetwork/srv/eng/metadata.show?uuid=ABC by
  * http://localhost:8080/geonetwork/?uuid=ABC
to make link working in all UI.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/835#comment:1&gt;
Keywords: |
Comment(by simonp):
Hi Francois,
Thanks for the tips on making the link work in all UI - I'll include that.
As for the gmx:Anchor versus gmx:FileName in otherCitationDetails etc - I
think I prefer the gmx:FileName at the moment for two reasons:
  * we build the whole gmd:thesaurusName block so no conflict with other
uses for otherCitationDetails/gmx:FileName
  * I don't think the xlink processor exclude option has been coded yet so
we would have issues with the xlink processor including the rdf/whatever
in here at present? (we run with xlink processing on by default here)
Thanks, Simon
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/835#comment:2&gt;
Keywords: |
Comment(by fxp):
Anchor looks to be used "here" more for keywords than thesaurus (so
gmx:FileName for thesaurus ref looks fine for me - I don't have example
for this). I may add basic support for keyword with Anchor later too (see
#681).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/835#comment:3&gt;
      Type: enhancement | Status: closed
Resolution: fixed | Keywords:
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Added in svn rev 8921
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/835#comment:4&gt;
