[GeoNetwork-devel] [GeoNetwork opensource Developer website] #837: language-index-field to be align to trunk
Reporter: fxp | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Some fixes to apply:
  * token attribute could be removed from all fields (it's defined in
config-lucene.xsl)
  * instead of using UPPER (ABCDEFGHIJKLMNOPQRSTUVWXYZ) and LOWER var and
translate function, you could switch to XSL v2 and use lower-case upper-
case function
  * trunk is not using + 360 shift for coordinates, because lat long are
indexed as numeric now.
  * "any" field indexing could probably be done using normalize-space
instead of recursive template loop - which is much faster. I've not tested
it but something like the following should be ok (you could have a look to
"any" in index-fields.xsl) :
<Field name="any" store="false" index="true" token="true">
  <xsl:attribute name="string">
   <xsl:value-of select="normalize-space(//node()[@locale=$langId])"/>
  </xsl:attribubte>
</Field>
  * default lang in function.xsl is set to "en" not "eng" ?
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/837&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Keywords: |
Changes (by fxp):
  * type: defect => enhancement
Comment:
Committed revision 8916.
  * Remove token parameter from language-index-fields (it's set in config-
lucene.xml).
  * Cleaning: remove unused namespace, use upper-case fct.
  * Used normalize-space for full text criteria instead of recursive loop.
  * Align bbox indexing in language-index-field to index-fields.
TODO :
  * Don't store all fields in index - only those used in q service
dumpFields
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/837#comment:1&gt;
Priority: major | Milestone: v2.9.0
Keywords: |
Changes (by ianwallen):
  * milestone: v2.7.0 => v2.9.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/837#comment:2&gt;
