#841: Data dir changes cause error on Windows
Reporter: heikki | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Since the change with datadir, on Windows you get lots of errors in the
console about files not found - the application directory path is
duplicated (see below).
Possibly this is because the generated schemaplugin-uri.xml contains a
file separator too many:
C:\_______qx\web\geonetwork/WEB-
INF/data/\config\schema_plugins/iso19139.geobru/present/metadata-iso19139
.geobru-edit.xsl
<error id="error">
<message>C:\_______qx\web\geonetwork\C:\_______qx\web\geonetwork\WEB-
INF\data\config\schema_plugins\iso19139.geobru\loc\eng\labels.xml (The
filename, directory name, or
volume label syntax is incorrect)</message>
<class>FileNotFoundException</class>
<stack>
<at class="java.io.FileInputStream" file="???" line="-2" method="open"
<at class="java.io.FileInputStream" file="???" line="-1"
method="<init>" />
method="<init>" />
<at class="sun.net.www.protocol.file.FileURLConnection" file="???"
line="-1" method="connect" />
line="-1" method="getInputStream" />
<at class="org.apache.xerces.impl.XMLEntityManager" file="???"
line="-1" method="setupCurrentEntity" />
<at class="org.apache.xerces.impl.XMLVersionDetector" file="???"
line="-1" method="determineDocVersion" />
<at class="org.apache.xerces.parsers.XML11Configuration" file="???"
line="-1" method="parse" />
<at class="org.apache.xerces.parsers.XMLParser" file="???" line="-1"
method="parse" />
<skip>...</skip>
<at class="jeeves.utils.Xml" file="Xml.java" line="219"
method="loadFile" />
<at class="jeeves.utils.XmlFileCacher" file="XmlFileCacher.java"
line="122" method="load" />
line="84" method="get" />
<at class="jeeves.server.dispatchers.guiservices.XmlFile"
file="XmlFile.java" line="109" method="exec" />
<at class="org.fao.geonet.services.schema.Info" file="Info.java"
line="171" method="getHelp" />
line="156" method="handleObject" />
line="124" method="handleElement" />
line="105" method="exec" />
<at class="jeeves.server.dispatchers.ServiceInfo"
file="ServiceInfo.java" line="230" method="execService" />
file="ServiceInfo.java" line="139" method="execServices" />
<at class="jeeves.server.dispatchers.ServiceManager"
file="ServiceManager.java" line="411" method="dispatch" />
<at class="jeeves.server.JeevesEngine" file="JeevesEngine.java"
line="723" method="dispatch" />
<at class="jeeves.server.sources.http.JeevesServlet"
file="JeevesServlet.java" line="196" method="execute" />
file="JeevesServlet.java" line="110" method="doPost" />
<skip>...</skip>
</stack>
<request>
<language>fre</language>
<service>xml.schema.info</service>
</request>
</error>
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/841>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
