[GeoNetwork-devel] [GeoNetwork opensource Developer website] #847: schemaPluginsDir in context.xml doesn't work as expected
Reporter: sha | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: schemaPluginsDir schema plugin config.xml |
After upload of a custom schema (via de GUI), the schema is placed in the
WEB-INF/data/config/schema_plugins directory.
I use geonetwork.war under tomcat so in our system the dir is:
/usr/share/tomcat6/webapps/geonetwork/WEB-INF/data/config/schema_plugins
I want this to be an other dir, because if geonetwork.war is redeployed,
the uploaded schema is gone.
In WEB-INF/config.xml I saw the following line:
<param name="schemaPluginsDir" value="schemaPlugins" />
I expect that if I change the value of this parameter to a different dir,
it might do the trick (store uploaded profiles at a custom defined dir
instead of the default one). Unfortunately that didn't work (nothing
changes). Also, I couldn't find documentation on changing the default dir
for the schema plugins.
Is the schemaPluginsDir meant for this purpose? If so, this currently
doesn't work (geonetwork r8955).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/847&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Comment(by fxp):
If you want to be able to redeploy the war, you should set a data
directory outside the webapp. The schema plugin is in the data directory.
See http://geonetwork-opensource.org/manuals/trunk/eng/users/admin
/advanced-configuration/index.html#geonetwork-data-directory
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/847#comment:1&gt;
      Type: defect | Status: closed
Resolution: fixed | Keywords: schemaPluginsDir schema plugin config.xml
Changes (by simonp):
  * status: new => closed
  * resolution: => fixed
Comment:
Removed obsolete schemaPluginsDir element from config.xml - schema plugins
are in the geonetwork data dir as described above.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/847#comment:2&gt;
