#850: errors in upgrade sql script in trunk
Reporter: jeanpommier | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Some lang codes ('sp', 'po') are erroneous in the migrate-default.sql
script. Another one is missing/removed.
No data is inserted for the new ones (vie, nor, fin)
I've fixed the erroneous and missing codes issues but not inserting data,
in the attached file.
'''However''', the upgraded database does not work :
ERROR [geonetwork.datamanager] - The metadata document index with id=134
is corrupt/invalid - ignoring it. Error: ERROR: current transaction is
aborted, commands ignored until end of transaction block
org.postgresql.util.PSQLException: ERROR: current transaction is aborted,
at
org.postgresql.core.v3.QueryExecutorImpl.receiveErrorResponse(QueryExecutorImpl.java:2062)
at
org.postgresql.core.v3.QueryExecutorImpl.processResults(QueryExecutorImpl.java:1795)
at
org.postgresql.core.v3.QueryExecutorImpl.execute(QueryExecutorImpl.java:257)
at
org.postgresql.jdbc2.AbstractJdbc2Statement.execute(AbstractJdbc2Statement.java:479)
at
org.postgresql.jdbc2.AbstractJdbc2Statement.executeWithFlags(AbstractJdbc2Statement.java:367)
at
org.postgresql.jdbc2.AbstractJdbc2Statement.executeQuery(AbstractJdbc2Statement.java:271)
at
org.apache.commons.dbcp.DelegatingPreparedStatement.executeQuery(DelegatingPreparedStatement.java:96)
at
at
at jeeves.resources.dbms.Dbms.selectFull(Dbms.java:210)
at jeeves.resources.dbms.Dbms.select(Dbms.java:181)
at
org.fao.geonet.kernel.XmlSerializer.internalSelect(XmlSerializer.java:92)
at
org.fao.geonet.kernel.XmlSerializerSvn.internalSelect(XmlSerializerSvn.java:72)
at
org.fao.geonet.kernel.XmlSerializerSvn.selectNoXLinkResolver(XmlSerializerSvn.java:107)
at
org.fao.geonet.kernel.DataManager.indexMetadata(DataManager.java:436)
at
org.fao.geonet.kernel.DataManager.indexMetadataGroup(DataManager.java:419)
at
org.fao.geonet.kernel.DataManager$IndexMetadataTask.run(DataManager.java:367)
at
java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at
java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/850>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
