#860: SchemaManager / autodetectschema / check namespace on default schema or its
dependencies
Reporter: fxp | Owner: geonetwork-devel@…
Priority: major | Milestone: v2.7.0
Component: General | Version:
Keywords: |
In r8622, the schema manager autodetect schema add an extra check on
default schema based on prime namespace comparison. When loading
subtemplates and using an ISO profil as preferred schema, default schema
usually does not match on primeNS usually.
Add prime namespace comparison for preferred schema dependency. If using
an ISO profil as a preferredschema, then a subtemplate matching ISO19139
will be properly managed (instead of rejected since r8622).
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/860>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
