[GeoNetwork-devel] [GeoNetwork opensource Developer website] #865: Place Thesaurus not populating Map Extents for ANZLIC in New GUI
Reporter: ByronCinNZ | Owner: geonetwork-devel@…
     Type: defect | Status: new
Priority: major | Milestone: v2.6.5
Component: General | Version: v2.6.5
Keywords: |
The allgens thesaurus that can be used in edit mode for ANZLIC metadata
only functions correctly in the classic GeoNetwork editor. In the new gui
it does not function correctly. The javascript function
''setAnzlicRegion'' embedded in metadata-iso19139.anzlic-edit.xsl is for
some reason unavailable when viewed in the new gui.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/865&gt;
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/&gt;
Priority: major | Milestone: v2.7.0
Keywords: |
Changes (by fxp):
  * version: v2.6.5 =>
  * milestone: v2.6.5 => v2.7.0
Comment:
I've not tested it but I think it's better to avoid JS in XSL (it will be
easier to maintain) and try to define element's id and/or class in order
to register events on the client side like what is done for tabs, calendar
init or map init for example.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/865#comment:1&gt;
  Keywords: |
Changes (by fxp):
Comment:
Actually planning to fix this by moving the thesaurus (anzlic allgens) into a register/thesaurus combo and then allowing the user to set the extent based on the keyword assigned from that thesaurus.
Priority: major | Milestone: v2.8.0
Keywords: |
Changes (by ianwallen):
  * milestone: v2.7.0 => v2.8.0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/865#comment:2&gt;
