#87: ISO 19139 output not valid XML
Reporter: tomkralidis | Owner: geonetwork-devel@lists.sourceforge.net
Type: defect | Status: new
Priority: major | Milestone: v2.3.0 Final
Component: Catalog server | Version:
Keywords: |
e.g. a response like:
http://devgeo.cciw.ca/geonetwork/srv/en/iso19139.xml?id=12 yields an
invalid document when processing with a validating parser.
Adding the following attribute to the root element of the response:
xsi:schemaLocation="http://www.isotc211.org/2005/gmd
http://schemas.opengis.net/iso/19139/20070417/gmd/gmd.xsd"
..will result in a valid document.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/87>
GeoNetwork opensource Developer website <http://trac.osgeo.org/geonetwork>
Component: Metadata standards | Version:
Resolution: | Keywords:
Changes (by tomkralidis):
* component: Catalog server => Metadata standards
Comment:
P.S. this would apply both to CSW response and URLs as above.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/87#comment:1>
Comment (by tomkralidis):
Note that for outputs of services, srv:SV_ServiceIdentification is output.
The 19119 schemas should be pointed to here in the case of service
metadata output.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/87#comment:2>
Priority: major | Milestone: v2.4.0 RC0
Changes (by ticheler):
* milestone: v2.3.0 Final => v2.4.0 RC0
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/87#comment:3>
Type: defect | Status: closed
Resolution: fixed | Keywords:
Changes (by heikki):
* status: new => closed
* resolution: => fixed
Comment:
Fixed for ISO19139 metadata. In case of service metadata, no
schemaLocation is added because there is no official schema for ISO19119.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/87#comment:4>
Type: defect | Status: reopened
* status: closed => reopened
* resolution: fixed =>
Comment:
Can we point to http://schemas.opengis.net/iso/19139/20060504/srv/srv.xsd
for 19119? The document won't validate, but it's much better than not
having on in place.
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/87#comment:5>
* status: reopened => closed
Comment:
OK, I've done that
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/87#comment:6>
