#874: Harvester / GeoNetwork protocol does not work due to 2 language code URL
redirection
Reporter: fxp | Owner: geonetwork-devel@…
Type: defect | Status: new
Priority: blocker | Milestone: v2.7.0
Component: General | Version:
Keywords: |
Error is on search request using 2 letter language code because method is
POST and !HttpClient is unable to automatically handle redirects.
2012-04-27 07:23:23,959 INFO [jeeves.service] - -> dispatch ended for :
xml.harvesting.run
2012-04-27 07:23:23,969 INFO [geonetwork.harvester] - Searching on : gs
2012-04-27 07:23:23,974 WARN [geonetwork.harvester] - Raised exception
when searching : BadXmlResponseEx :
while harvesting from : gs (GeonetHarvester)
2012-04-27 07:23:23,975 WARN [geonetwork.harvester] - (C) Class :
OperationAbortedEx
2012-04-27 07:23:23,975 WARN [geonetwork.harvester] - (C) Message :
Raised exception when searching
OperationAbortedEx : Raised exception when searching
at
org.fao.geonet.kernel.harvest.harvester.geonet.Harvester.doSearch(Harvester.java:178)
at
org.fao.geonet.kernel.harvest.harvester.geonet.Harvester.search(Harvester.java:138)
at
org.fao.geonet.kernel.harvest.harvester.geonet.Harvester.harvest(Harvester.java:117)
at
org.fao.geonet.kernel.harvest.harvester.geonet.GeonetHarvester.doHarvest(GeonetHarvester.java:266)
at
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester$HarvestWithIndexProcessor.process(AbstractHarvester.java:382)
at
org.fao.geonet.kernel.MetadataIndexerProcessor.processWithFastIndexing(MetadataIndexerProcessor.java:39)
at
org.fao.geonet.kernel.harvest.harvester.AbstractHarvester.harvest(AbstractHarvester.java:410)
at
org.fao.geonet.kernel.harvest.harvester.Executor.run(Executor.java:87)
Ticket URL: <http://trac.osgeo.org/geonetwork/ticket/874>
GeoNetwork opensource Developer website <http://sourceforge.net/projects/geonetwork/>
